TwinTurbo.NET: Nissan 300ZX forum - The dip stick reference will not work work with >>
Subject The dip stick reference will not work work with >>
Posted by ZUL8TR on June 09, 2013 at 5:45 AM
  This message has been viewed 164 times.
In Reply To After I add the recommended amount I verify posted by SammybTT(TN) on June 07, 2013 at 07:54 PM
Message a bench fill. The final topping off needs to be done after the engine is started and shut off and level allowed to stabilize. At the factory they probably know the correct amount of total oil to add to fill all the lines, coolers, etc so as to be correct at the dip stick. The owners manual refill amount is for normal gravity drain and filter replacement conditions.
ZUL8TR in Orlando,FL
